@Seve for the nema17 motor, can you
mention for the nema17 motor, can you share the real male pin image of the motor. I am wondering which one of these would fit.
Started by RishabhNov 2, 20267 messages
Last active 3 days ago · plain text
Rishabhoriginal post
<@757706909351411845> for the nema17 motor, can you share the real male pin image of the motor. I am wondering which one of these would fit.
those won't fit, the pitch is the same but they don't snap in
https://www.omc-stepperonline.com/nema-17-bipolar-42ncm-59-48oz-in-1-7a-42x42x37-5mm-4-wires-w-1m-cable-connector-17hs15-1704s
the photos here are good, if it doesn't snap in it's not going to work, the pins do slide out on dupont connectors
I couldn't find anything specific to this usecase to directly plug into the male motor pins. Some kind of terminal jst/wago kind of a thing would be needed
yea we need a jst connector
jst ph or whatever
