https://tscircuit.com/AnasSarkiz/NEMA14_
https://tscircuit.com/AnasSarkiz/NEMA14 RP2040 3d
Started by AnasOct 13, 202625 messages
Last active 23 days ago · plain text
Anasoriginal post
https://tscircuit.com/AnasSarkiz/NEMA14_RP2040#3d
add knockout text for PWR and DATA
Even the schematic used for usbc is not standard
I don't think bulk capacitor is needed
you should do the assembly- i don't think the bolts will fit
<@756504518417711104> you should try to get the encoder with doNotPlace on the back, we may be adding those because they turn the steppers into servos and add a lot of value
this is the only way to make the two USB-Cs on the same side, so I think we need to replace the bolts with other ones
the crystal traces are really bad!
you can use upward usb-c if it is going to help spacing a lot
yeah it will helps alot
why does your board have 0 warnings and errors if the crystal is so bad
thats what Im trying to debug rn 🫠
this is one of the best schematics i've seen
I agree, I just tald Ai to make it professional lol
Can you check if these overriding values of clearance are more than the jlc tolerance capability?
Fixed via size, crystal trace, and using the correct bolts size. so I will do assemply but just check this <@809856037376491570> <@757706909351411845> https://tscircuit.com/AnasSarkiz/NEMA14_RP2040#3d
<@398467566588264449>
looks pretty good to me
schematic is decent
<@809856037376491570> <@398467566588264449> could u take a look
lg
<@809856037376491570> Im gonna order it
