https://tscircuit.com/rushabhcodes/
https://tscircuit.com/rushabhcodes/turncount 3d
Started by ! Rushabh | Linux ShillOct 6, 202621 messages
https://tscircuit.com/rushabhcodes/turncount#3d
why isn't your AI fixing the decoupling cap warnings/errors? Are they not throwing?
no error or warning
<@452450065941004289> your decoupling caps aren't placed properly, figure out the warning and fix
like on the pcb
it should be throwing an error
it shouldn't even route
also you should do a full assembly for this, as of now i think you probably will have to drop this because i don't think you're moving fast enough, gotta 5x the speed, should be looking at 2 design reviews daily for this kind of stuff
everyone has to order by tomorrow
also the turn counter was never supposed to connect over bluetooth so this is also confusing
the turn counter was always supposed to be NFC
i just don't think you have a good grasp on the product here
With NFC, the MCU could update a dynamic NFC tag with the latest count, but the iPhone doesn't treat a normal NFC tag like a continuously connected peripheral. Reading the updated value generally requires an NFC interaction, so it isn't ideal if we want the number on the phone screen to change live as the knob is rotated.
With BLE, the MCU can keep counting locally and send updated values to the iPhone while the device remains connected. That gives us the experience I was trying to achieve:
I just sent the board for review, and I’m already working on the full 3D enclosure assembly.
I’ll share that next as soon as it’s ready for review.
you don't need it to be continuously connected, use a tscircuit assembly
don't use ble, you don't need continuous reading, also you need magnets to stick to the iphone
