Seve - Linux is running!!! https://x.com/seveib...
Linux is running!!! https://x.com/seveibar/status/2105089653795873274?s=20 We now have a way to run linux, Huzzah! https://tscircuit.com/seveibar/f1c1990s dev board
Started by SeveSep 30, 202613 messages
Linux is running!!! https://x.com/seveibar/status/2105089653795873274?s=20 We now have a way to run linux, Huzzah! https://tscircuit.com/seveibar/f1c1990s-dev-board
Wow
NOTE: package was renamed https://tscircuit.com/seveibar/f1c100s-linux-dev-board#files
this is crazyyy
only dram is left ig
and we're not too far from that!!! https://tscircuit.com/seveibar/am3352-ram-dogbone-and-single-layer-route-test#pcb
how did it get that clean
but yea DRAM is really the last major thing imo
it is an algo, you can read my chat, i told it to optimize to reduce certain things that i specified
https://chatgpt.com/s/cx_6abc9c9362cc8191a3faf506eae865b2 < start from the top (I'd recommend)
<@757706909351411845> what was the exact issue with the pcb? did you swap the regulator in your tscircuit.com package or not? also how well did linux run?
the package is fixed now, i didn't do a performance test and will try to plug in a SPI screen tomorrow and run something that can sort of show us the speed of the thing (although it is a PITA with the variable power supply) i replaced one of the 3 regulators with a variable power supply to provide the correct voltage linux ran totally fine, it is a linux command line so not much to it until we install python or something 😁
I got sabotaged by 6.1 Sol. It spent the whole morning basically doing the same thing while trying to route a Pico 2W using the AM3352, and it made absolutely zero progress. It had no idea what was going on. What makes even less sense is that I used Sol 6 to route the same board, the same chip, and the same RAM before. AHHHH
