https://tscircuit.com/rushabhcodes/ESP32
https://tscircuit.com/rushabhcodes/ESP32 E Reader pcb
Started by ! Rushabh | Linux ShillSep 23, 20268 messages
https://tscircuit.com/rushabhcodes/ESP32-E-Reader#pcb
<@778624824875941908> || <@809856037376491570> review please
Also, why do you have switches at the bottom layer
Have single layer assembly
the bottom layer will have the screen and the switch below and the top has all the circuit, that was the plan
In that case, the switches are two small. Use bigger switches so that the 3d case can fit over it and you can press the button
this is looking pretty good, if you want it to mount in a case things make sure you're placing holes etc.
