mohan-bee - Guys i have been doing some one sho...
Guys i have been doing some one shot prompt board and capture their benchmark to see how the AI working with kicad and tscircuit here is the results https://tscircuit gpt benchmark.vercel.app/
Started by mohan-beeSep 5, 202638 messages
Guys i have been doing some one shot prompt board and capture their benchmark to see how the AI working with kicad and tscircuit here is the results https://tscircuit-gpt-benchmark.vercel.app/
we are doing good in schematic ig
looks good
but what is this
Easyeda issue
https://github.com/tscircuit/easyeda-converter/pull/542
it's a bit confusing with the time thing
we need to measure times well because we're doing really well compared to openai astra for time at the moment
Time is not accurate for sure
True
our schematic seems much worse
it's spread out etc
good comparison tho
yea
we need to expand this more! maybe an official benchmark were we make model give score and see if we improve or go down i think if we write the rules right it should be deterministic ish most of the time
yep 100%
also our auto router being more successful might be making the model do the placement worse
for sure
seve what can we do to avoid that spread out in schematic placement.. because I am noticing this pattern in every one shot prompted board.
do we have a warning emitted if there isn't a schematic sheet or if components are outside the schematic sheet?
We could also warn on long schematic traces 🤔
you mean we need to default to sheets ?
no, but we can warn if there's a missing sheet
hmm
because then it won't spread out components because it'll throw outside-of-sheet errors
idk
or we just warn on long schematic traces
i think that might also be ok but the issue there is it's kind of a schematic trace solver issue
🤔 leme try to figure this out to
i tried to use the schematicsheet for that sheet .. but the ai just wrapped the large schematic with the sheet using a custom size ..
i am not sure what could improve this
i think autoloayout is doing some good job.
i think we should avoid using explicit schX and schY then
why are we vertically stacking caps like that... that's quite bad haha
that is done by astra with schx and schy .
