Vivek Vijayan - Is this the right approach to u...
Is this the right approach to use exposedNets code sample
Started by Vivek VijayanJul 20, 202617 messages
Vivek Vijayanoriginal post
Is this the right approach to use `exposedNets` ``` export const SensorFrontEnd = () => { return ( <subcircuit exposedNets={["VCC","GND", "SIG_OUT"]} name={name} showAsSchematicBox={showAsSchematicBox}> <port name="VCC" direction="left" connectsTo={["R_p.pin1"]} /> <port name="GND" direction="left" connectsTo={["C_f.pin2"]} /> <port name="SIG_OUT" direction="right" connectsTo={["R_p.pin2"]} /> <resistor name="R_p" resistance="10k" footprint="0603" /> <capacitor name="C_f" capacitance="100nF" footprint="0603" /> <trace name="tr_internal_sig" from=".R_p.pin2" to=".C_f.pin1" /> </subcircuit> ) } export const SignalProcessor = () => { return ( <subcircuit name={name} exposedNets={["VCC","GND", "SIG_IN"]} showAsSchematicBox={showAsSchematicBox}> <port name="VCC" direction="left" connectsTo={["R_l.pin1"]} /> <port name="SIG_IN" direction="left" connectsTo={["R_l.pin2"]} /> <port name="GND" direction="right" connectsTo={["C_d.pin2"]} /> <resistor name="R_l" resistance="1k" footprint="0402" /> <capacitor name="C_d" capacitance="1uF" footprint="0402" /> <trace name="tr_internal_vcc" from=".R_l.pin1" to=".C_d.pin1" /> </subcircuit> ) } export const ControlCircuitSystem = () => { return ( <group name={name} showAsSchematicBox={showAsSchematicBox}> <SensorFrontEnd name="sensor" showAsSchematicBox={true} /> <SignalProcessor name="processor" showAsSchematicBox={true} /> <trace name="t_signal_bus" path={["sensor.SIG_OUT", "processor.SIG_IN"]} /> <trace name="t_vcc_bus" path={["sensor.VCC", "processor.VCC"]} /> <trace name="t_gnd_bus" path={["sensor.GND", "processor.GND"]} /> <port name="SYS_VCC" direction="left" connectsTo={["sensor.VCC"]} /> <port name="SYS_GND" direction="left" connectsTo={["sensor.GND"]} /> </group> ) } ```
Vivek Vijayan
I found the mistake. Instead of `exposeNets` boolean, I was using `exposedNets` string[]. Now I can connect subcircuits with each other. Still schematic view is buggy. In the code, there is a connection between lvps.SEC_GND and mcu.GND. But it is not rendering properly. ``` {/* Power: LVPS 3.3V to MCU 3.3V */} <trace name="t_v3v3_link" path={[".lvps > .VOUT_3V3", ".mcu > .3V3"]} /> <trace name="t_gnd_link" path={[".lvps > .SEC_GND", ".mcu > .GND"]} /> ``` Also the ports are assigned with name <subcircuit_name>_connectivity_net<number>
Yea that is awful- cc <@1079361271687807026> (we must never manipulate names!)
<@757706909351411845> isnt this repro https://github.com/tscircuit/core/pull/2735/files same as above circuit? you meant to fix the connectivity net names leaking right?
The fix is the remove those netlabels right?https://github.com/tscircuit/core/pull/2738 Can you please clarify
The visual snapshot needs explatory text
Assume the viewer cant see the test code- because you repro’d separately i literally cannot
It is impossible to review!!!! I have no idea what im seeing!!
i'll create a separate repro and tag you
If i expand test content i can see the code
But the visual snapshot needs explanatory text IN the schematic snapshot
So it is possible to review if i expand code on github
https://github.com/tscircuit/core/pull/2742
Closing as i think the behaviour might be correct, confusing and difficult to understand for now, Let me know if these "...connectivity_net0" etc netlabels are correct behaviour.
The connectivity net id net labels are not the correct behavior
For my review- i was commenting on your schematic text, it doesnt describe the issue
