Seve - @Abse do you want to chat on voice
it's a standard pin header
Started by SeveJun 26, 202699 messages
we should populate it with FEMALE pinheaders
that might be complex depending on how it's defined 😬
yeah I'm going with a female didn't pick a part number yet
cool
btw jlcsearch has a dedicated page for JST connectors https://jlcsearch.tscircuit.com/jst_connectors/list
let's use 2mm pitch it's wayyyyyy more common
maybe this https://jlcpcb.com/partdetail/BM02B-PASS-TFT(LF)(SN)/C265372
https://jlcsearch.tscircuit.com/jst_connectors/list?package=SMD%2CP%3D2mm&num_pins=2&pitch_mm=2
https://jlcpcb.com/partdetail/SM02B-PASS-TBT(LF)(SN)/C265417
<@757706909351411845> http://github.com/tscircuit/cli/pull/3485
https://www.lcdwiki.com/2.8inch_SPI_Module_ILI9341_SKU:MSP2807
yea seems solid
<@757706909351411845> I think we are done 😮‍💨
https://tscircuit.com/editor?package_id=bdff6d37-760b-4aff-8ab1-fae5bc833e32&file_path=index.circuit.tsx
plz review, mouting holes will be added now
Afk 😭
haha no worries let me know what you thing when you see it I will order it in the morning is that ok ?
can we still make it ?
Yea i think so
Yea probably
I added long buttons and long 5mm long power switch
If u screenshot it i can at least confirm some stuff if u want to order
Up to you
3d and pcb can help me do a quicj check
Doesnt load on my phone
Oh
No mounting holes for the board?
this is pre holes
Oh
pushing rn
Looks good
the power circuit is crazy
lol
Hmm
One possible concern is the button height vs screen height
We can make it work either way but the buttons should stick out beyond the screen
in theory, when usb c plugged should not drain the bat etc
In theory haha
You have to have isolation
Hopefully the ai did that
If the schematic isnt clean impossible to review it as an EE
I tried to clean it not sure if I don't know how or it does not work ?
Is button height >12mm to be outside screen
tried to use sections no schx/y etc
the datasheet is dumb showing the short version let me look
Put name prop on all traces and use schematic sections, you CAN use schX/schY
In fact its better to provide schX and schY to incrementally improve
Haha yea a bit tricky
button height is 10 mm
should I look for 15 ?
I guess so
Otherwise the case has to have the screen kind of pop out ig
I will export to STEP and try a design tonight?
15 mm pushbuttons and mounting holes
heading to bed
not sure we can clean sch alot
Cc <@1079361271687807026> <@436098556974333952> this has to be fixed!!!! Cant review this- it is a bug!!!!
Will review now and do quick model
<@398467566588264449> PCB looks good but really wish i could review schematic- we definitely need to get this label issue resolved ASAP!
might take a look if nobody else is
sry I can't it's 2 AM here and I'm exhausted
ur good i meant mustafa or sangit
wow this STEP file has a lot of bugs
<@398467566588264449> what's the JST connector in the center of the board for?
did a very basic case, it was hard to do without the step but i think it should fit!
Speaker will connect there and be mounted on the Gameboy case right?
ohhh
yea i have to have a place for the speaker
does it have volume control via a potetiometer btw?
forgot about it completely
I will try to add a potetiometer quickly
if you want to be real crazy you could put a right angle potentiometer (a small one) on the side- then volume could be adjusted by the user
can't review schematic until that other bug is fixed- up to you if you want to order before we do a proper schematic review
That what I was thinking about haha
I will put the volume control on the left
<@1079361271687807026> might wake up soon and be able to help with the trace name fix, which i think is a pretty big deal (good find on your part- will probably effect ti)
Yeah I can wait
name on trace is not working?
It should create a short label according to name
it's not working for the subcircuits, check out his circuit
<@398467566588264449> https://github.com/tscircuit/core/pull/2538
Lgtm but you have test failing
<@398467566588264449> looks much cleaner now, but you have some bad schX/schY coordinates in the subcircuits. You need to fix that.
Will fix them ty
<@400684445054795796> I don't understand, when I generate the srj from core and run it in autoruoter it works but it still fail on tscirucit.com and on the cli when trying to route ?
version issue ?? the core is not on latest auto router
https://github.com/tscircuit/core/pull/2557/changes#diff-7ae45ad102eab3b6d7e7896acd08c427a9b25b346470d7bc6507b6481575d519
I'm losing my mind
<@398467566588264449> status?
is their any other problem <@398467566588264449> with this; you said something is wrong do you also mean this issue or something else
same issue yeah
