Abse - I added some new stuff of the https://ca...
I added some new stuff to the https://cad component viz.vercel.app/ check it out
Started by AbseJun 1, 202661 messages
Abseoriginal post
I added some new stuff to the https://cad-component-viz.vercel.app/ check it out
it looks really good!
definitely should be useful!
<@757706909351411845> wdyt about this https://docs-git-fork-abse2001-main-tscircuit.vercel.app/contributing/contributing-autorouting-dataset
let me know if it's messing something or something is not correct
This is a good start but it needs a lot more references, link to the bootstrapping repos and dataset guidelines rather than including all the information in the doc
Also add more details about adding a fixture with the dataset to the autorouting repo
Otherwise looking good, getting there
also do you want the BGA datasets on there own repos ?
also can you check the component detection and topology generatioan for nested qfp components https://capacity-node-autorouter-git-fork-abse2001-qfp-tscircuit.vercel.app/?fixtureId=%7B%22path%22%3A%22fixtures%2Fbenchmarks%2Fdataset-srj18.fixture.tsx%22%7D
https://capacity-node-autorouter-git-fork-abse2001-qfp-tscircuit.vercel.app/?fixtureId=%7B"path"%3A"fixtures%2Fbenchmarks%2Fdataset-srj18.fixture.tsx"%7D
if you check sample 8
we have a passive components under qfp issue not sure how to handel them
hello sorry for the delay
<@398467566588264449> the QFP topology generation looks really good?
do we know if this has any impact on performance (hopefully good) or on benchmark?
we Improved one board
and failing in one
so no change but I'm working on a fix for the failling one
https://github.com/tscircuit/tscircuit-autorouter/pull/1332
the failling sample is 8 in the srj18
it fail for the passive components on top of the QFP
<@757706909351411845> how is this https://docs-isjj0nxcm-tscircuit.vercel.app/contributing/contributing-autorouting-dataset
https://github.com/tscircuit/dataset-srj19/pull/1
<@757706909351411845> can we merge this ? https://github.com/tscircuit/docs/pull/700
I can't merge
also this is needed for footprinter https://github.com/tscircuit/kicad-to-circuit-json/pull/139
<@757706909351411845> can I get a review?
https://github.com/tscircuit/system-diagram-proposal/pull/1
Some images failing for me but the first 6 are good
You probably need some simple ones and some different styles 🤔 a lot of system diagrams are pretty simple flowchart-ish things. Eg But i think this is pretty good
Now u gotta generate them
hey <@757706909351411845>
``` const antennaPoints = [ { x: 0, y: 0 }, { x: 9, y: 0 }, { x: 9, y: 2.6 }, { x: 3, y: 2.6 }, { x: 3, y: 5.2 }, { x: 9, y: 5.2 }, { x: 9, y: 7.8 }, { x: 3, y: 7.8 }, { x: 3, y: 10.4 }, { x: 9, y: 10.4 }, { x: 9, y: 13 }, ] const traceWidth = 0.45 const antennaSegments = antennaPoints.slice(0, -1).map((start, index) => { const end = antennaPoints[index + 1] const horizontal = start.y === end.y return { pcbX: (start.x + end.x) / 2, pcbY: (start.y + end.y) / 2, width: horizontal ? Math.abs(end.x - start.x) + traceWidth : traceWidth, height: horizontal ? traceWidth : Math.abs(end.y - start.y) + traceWidth, } }) export default () => ( <board width="18mm" height="24mm"> <chip name="ANT1" pcbX={-6} pcbY={-8} pinLabels={{ pin1: ["ANT"], }} pinAttributes={{ pin1: { providesSignal: true }, }} footprint={ <footprint> <smtpad portHints={["pin1"]} pcbX="0mm" pcbY="0mm" layer="top" shape="rect" width="1mm" height="0.7mm" /> {antennaSegments.map((segment, index) => ( <smtpad key={index} portHints={["pin1"]} pcbX={`${segment.pcbX}mm`} pcbY={`${segment.pcbY}mm`} layer="top" shape="rect" width={`${segment.width}mm`} height={`${segment.height}mm`} /> ))} <smtpad portHints={["pin1"]} pcbX="9mm" pcbY="13mm" layer="top" shape="rect" width="0.01mm" height="0.01mm" /> </footprint> } /> </board> ) ```
I managed to make the antenna like this, but this is a hack no ?
not sure if we have manual trace component or prop that I'm not aware of ?
the trace need from to and from the image he sent the antenna don't have to
https://github.com/tscircuit/system-diagram-proposal/pull/3
Did we get in ant of the antenna stuff? Your code there is a crazy hack just use pcbPath of trace
The antennaPoints var is nice but the antenna doesnt look right to me- make sure its accurate
https://github.com/tscircuit/system-diagram-proposal/pull/4
<@757706909351411845> can you review this
can you check if this fix is a hack or legit ? https://github.com/tscircuit/core/pull/2679
if not the fix how should the fix be ?
yea checking now
my bad pushed to the wrong bracnh
one sec
kk
<@757706909351411845> https://github.com/tscircuit/core/pull/2681
<@400684445054795796> can you review this agian
<@757706909351411845> for the common pico what should we name it ? and should we add part numbers or just footprints ?
<@757706909351411845> <@400684445054795796> https://github.com/tscircuit/core/pull/2714
<@757706909351411845> is there a github issues ? CIs faillling ?
