Conclusion for rushabhcodes/usb-c-e-paper-display v1.2.1: electrically sound and ready for a prototype order.
No shorts and no open nets. All 45 nets connect across the four layers, and nothing is closer than 0.15 mm.
The circuit is correct. USB-C, the 3.3 V regulators, the RP2040 with its flash and crystal, the display connector, and the panel boost and charge pump all check out against their pinouts.
Two things to sort out, neither of which is a board fault:
Firmware must avoid back-powering the panel. Before GPIO14 turns the display rail off, it should drive the display pins (SPI clock and data, DC, reset, chip-select) low.
The source doesn't rebuild from the published package. The lockfile and the core patch target different versions, and the build fails. The board I reviewed is the registry's own built output, which is clean. This only matters if you want to change the design.
