! Rushabh | Linux Shill - Proposal: Add a PCB S...
Proposal: Add a PCB Stackup View to tscircuit Add PCB → Layers → View Stackup to display layer order, copper and dielectric thicknesses, and available material properties. Circuit JSON already supports detailed stackup records, and Core can populate them from imported data or fab
Started by ! Rushabh | Linux ShillNov 24, 20264 messages
Last active 43 minutes ago · plain text
**Proposal: Add a PCB Stackup View to tscircuit** Add **PCB → Layers → View Stackup** to display layer order, copper and dielectric thicknesses, and available material properties. Circuit JSON already supports detailed stackup records, and Core can populate them from imported data or fabricator presets. The proposed initial scope is a read-only cross-section and layer table, with missing dimensions clearly marked as unspecified. - **[`pcb-viewer`](https://github.com/tscircuit/pcb-viewer):** Implement the view and visual tests. - **[`runframe`](https://github.com/tscircuit/runframe) and [`tscircuit.com`](https://github.com/tscircuit/tscircuit.com):** Update dependencies and verify integration. - **[`docs`](https://github.com/tscircuit/docs):** Document usage. The view would help inspect tscircuit’s source data. Exported files would still require independent validation, as shown above in Altium 365 Viewer.
<@757706909351411845> <@809856037376491570>
<@398467566588264449>
