Tenacious B - @Seve somthing like this is int t...
mention somthing like this is int the works: code sample
Started by Tenacious BNov 14, 20263 messages
Last active 8 days ago · plain text
Tenacious Boriginal post
<@757706909351411845> somthing like this is int the works: ```tsx /** * ISO-style hex bolt and nut, sized from the metric thread table. The hex heads get the classic * 30° chamfer by intersecting the prism with a double cone; threads are cosmetic grooves. */ import { defineParams, type ParamValues } from "tscad" /** ISO 4014/4032 dimensions: thread Ø → [pitch, across-flats, head height, nut height]. */ const METRIC = { M3: [0.5, 5.5, 2, 2.4], M4: [0.7, 7, 2.8, 3.2], M5: [0.8, 8, 3.5, 4.7], M6: [1, 10, 4, 5.2], M8: [1.25, 13, 5.3, 6.8], M10: [1.5, 16, 6.4, 8.4], M12: [1.75, 18, 7.5, 10.8], } as const export const params = defineParams({ size: { type: "choice", default: "M8", options: Object.keys(METRIC) as (keyof typeof METRIC)[], label: "Thread" }, length: { type: "number", default: 30, min: 8, max: 120, step: 1, unit: "mm", label: "Shank length" }, grooves: { type: "boolean", default: true, label: "Cosmetic thread" }, gap: { type: "number", default: 12, min: 0, max: 60, step: 1, unit: "mm", label: "Nut position" }, }) /** A hexagonal prism with both ends chamfered at 30°, standing on z = 0. */ function ChamferedHex({ acrossFlats, height, z = 0 }: { acrossFlats: number; height: number; z?: number }) { const R = acrossFlats / Math.sqrt(3) // circumradius const r0 = acrossFlats * 0.475 // chamfer starts just inside the flats const r1 = R * 1.05 // ...and clears the corners const c = (r1 - r0) * Math.tan(Math.PI / 6) // 30° chamfer return ( <intersection z={z}> <extrude height={height}> <regularPolygon sides={6} flats={acrossFlats} /> </extrude> {/* a barrel with 30° conical ends: cuts the chamfer at both ends of the prism */} <union> <cone r1={r0} r2={r1} h={c} /> <cylinder r={r1} h={height - 2 * c} z={c} /> <cone r1={r1} r2={r0} h={c} z={height - c} /> </union> </intersection> ) } export default function BoltAndNut(p: ParamValues<typeof params>) { const d = Number(p.size.slice(1)) const [pitch, af, headH, nutH] = METRIC[p.size] const grooveCount = Math.floor((p.length * 0.7) / pitch) return ( <assembly name="fastener"> <part name="bolt" color="#9aa3ad"> <difference> <union> <ChamferedHex acrossFlats={af} height={headH} /> {/* shank with a chamfered tip */} <cylinder r={d / 2} h={p.length - pitch} z={headH} /> <cone r1={d / 2} r2={d / 2 - pitch} h={pitch} z={headH + p.length - pitch} /> </union> {/* cosmetic thread: a stack of shallow V-grooves along the lower 70% */} {p.grooves && ( <linearPattern count={grooveCount} step={[0, 0, pitch]}> <torus R={d / 2 + pitch * 0.15} r={pitch * 0.35} z={headH + p.length * 0.3 + pitch / 2} /> </linearPattern> )} </difference> </part> <part name="nut" color="#c9ced4" z={headH + p.gap}> <difference> <ChamferedHex acrossFlats={af} height={nutH} /> <cylinder r={d / 2 - pitch * 0.3} h={nutH * 3} z={-nutH} /> </difference> </part> </assembly> ) } ```
amazing
yea this is exactly what we need
