0hmx - Problem: <trace path> is unordered today...
Problem: <trace path is unordered today. It's just a set of pins to connect. Making the order meaningful would change the behavior of every trace that uses path. The workaround (what core 5384 does) is to treat the order as meaningful only when a <differentialpair references the
**Problem:** `<trace path>` is unordered today. It's just a set of pins to connect. Making the order meaningful would change the behavior of every trace that uses `path`.
The workaround (what core #5384 does) is to treat the order as meaningful only when a `<differentialpair>` references the trace. I don't like that: it's hidden, undocumented behavior that you can't see by looking at the trace.
**Proposal:** give `<differentialpair>` two flat props that list each lane's pins in signal order, from the first pin to the last:
```tsx
<differentialpair
name="USB"
positiveOrderedPath={["J1.DP", "ESD.IO1", "R1.pin1", "R1.pin2", "U1.DP"]}
negativeOrderedPath={["J1.DM", "ESD.IO2", "R2.pin1", "R2.pin2", "U1.DM"]}
maxLengthSkew="0.1mm"
This keeps `<trace path>` exactly as it is, makes the order explicit where it matters, and gives the router what it needs: an ordered list of pins per lane, which maps directly onto the SRJ "path of point ids". The props are flat rather than nested, following the handbook (§1.2, "avoid nesting").
`positiveConnection` and `negativeConnection` are **deprecated** but keep working, so existing designs don't break. <@757706909351411845>
i think path is ordered
path should be ordered i think
<@400684445054795796> you REALLY need to be careful, because even though we've discussed this a lot, you've dropped the VERY IMPORTANT `connectionPath` naming
you've omitted `connection`, which is so important
<@809856037376491570> note the comment regarding core not always treating the path is ordered, that is a bug you've introduced here. The path should always be ordered, not conditionally
R
Ohh
the auto router uses the mst and dose not respect core; this is more on the auto router side; not because of <@809856037376491570>
core respects the order internally but auto router dose not care
the netpointpairssolver should use the path given by the user
R
https://github.com/tscircuit/length-matching-solver/pull/87
https://github.com/tscircuit/tscircuit-autorouter/pull/3643
cc <@400684445054795796> <@757706909351411845>
This was the approach I had
i think your autorouter isn't using the path data properly- i could be wrong
