https://tscircuit.com/rushabhcodes/
https://tscircuit.com/rushabhcodes/simple usb c pd peltier driver
Started by ! Rushabh | Linux ShillNov 11, 20265 messages
Last active 11 days ago · plain text
https://tscircuit.com/rushabhcodes/simple-usb-c-pd-peltier-driver
I think some 3d modles are missing. We also need detailed assembly, including the exact wiring and connections for the sensors and the Peltier module. Ideally, we should specify the exact components we'll be using, along with purchase links from Amazon or other reliable suppliers.
ooh ok
also add some diagram to explain how it works can share the diagram here ig
Also, a tip: Ask an AI, especially Fable 5.2, to critically review your work. Push it to be extremely strict and make it clear that this is going to be a real-world product, so it needs to identify every possible flaw. Give it permission to suggest major changes or even a complete redesign if necessary. Then run a **review → fix → review** loop at least three times. Keep track of all the issues the AI identifies, the changes you make, and whether those issues are actually resolved after each iteration. even allow multi board design like the pcb is broken into smaller modules; let it know even the traget price range to sell; just have some more different design of the products; have 2-3 diff board design
