@Abse https://tscircuit.com/AnasSarkiz
mention https://tscircuit.com/AnasSarkiz/NEMA14 RP2040 V2 3d CC: mention mention
Started by AnasNov 3, 202619 messages
Last active 2 days ago · plain text
Anasoriginal post
<@398467566588264449> https://tscircuit.com/AnasSarkiz/NEMA14_RP2040_V2#3d CC: <@809856037376491570> <@757706909351411845>
NEMA14 V2 Both coil currents are connected to the RP2040 ADCs Both encoder capacitors on top Using Wago instead of JST
V1 https://tscircuit.com/AnasSarkiz/NEMA14_RP2040#3d
<@809856037376491570> would u take a look before Im gonna order it?
what's the reason for using buck?
it will be very confusing to figure out the pwr and data usb, the silkscreen is not great
Its for step-down the voltage V1 uses the same buck.
I know but I dont have space to add it in the top
so thats why I added it in bottom
Make it big in the bottom layer
will make it big knockout
I didn't catch this, but make it single side assembly. You need to move the capacitor to the top layer, so later on if we add encoder it would be just that
You can remove the test points, if space is a concern
This is v1
Here is v2 https://tscircuit.com/AnasSarkiz/NEMA14_RP2040_V2#3d
Ohh okay
looks good then
