โ† Back to community index
# contributorยทActive
Seve - this is basically the ideal motor contro...
this is basically the ideal motor controller connector, if we put these on every controller we would be ๐Ÿ‘Œ
Started by SeveOct 27, 20269 messages
Last active 13 days ago ยท plain text
spring clamp connectors are a category https://jlcpcb.com/parts/2nd/Connectors/Spring_Clamp_System_Terminal_Block_2974
no more jst and precrimpped wiring stuff? switching to these?
these would be far better if we can use them
i think they're just really big
we should use them for the NEMA23/NEMA34 probably
okay, so experimentation needed with these
yea if we can get it on a NEMA17 it'd be huge
Let's get the order and demand going up, and we can try to optimise the process
Continue in Discord โ†—
