NEMA17 LINUX
mention nema17 linux motor controller board: https://tscircuit.com/shibosoftwaredev/f1c100s linux nema17 stepper controller 3d
Started by shiboOct 22, 202619 messages
Last active yesterday · plain text
<@809856037376491570> nema17 linux motor controller board: https://tscircuit.com/shibosoftwaredev/f1c100s-linux-nema17-stepper-controller#3d
Move the bulk capacitor to the top layer, so it doesn't causes issue while mounting this to the back of the motor
schematic's is not great, I am not an electrical engineer so I can't understand those stuff until you add sections and description to each of those unfortunately 😅
<@809856037376491570> please check again
nema17: https://tscircuit.com/shibosoftwaredev/f1c100s-linux-nema17-stepper-controller#3d nema8: https://tscircuit.com/ShiboSoftwareDev/nema8-20mm-dual-usbc-stepper-controller#3d
I don't see any obvious issues
There are no encoders on them though
But I think these look good, get a final review from <@757706909351411845>
we should move forward with the NEMA8
the NEMA17 w/ linux is pretty cool, we should see if we can also support PoE (Power Over Ethernet) which would make it really good
i'm asking AI some questions about the linux NEMA17, stand by
NEMA17 LINUX
current levels are now configurable
power over ethernet requires a lot of circuitry, I tried to fit it into the board with no success
Can you tell me more RE:additional circuitry
When I asked what's the difference between it and usb-pd - USB-PD: sharing an electrical ground with the connected device is normal. Our board accepts the power and adjusts the voltage. - Ethernet: the network cable is normally electrically separated from the board. Taking power directly from it could bypass that separation. The PoE transformer lets power cross while keeping the two sides electrically separate, which matters when our board also connects to a computer over USB.
<@757706909351411845> this was the last chat regarding the linux nema17
