mention the board page is returning 504. The releases list API took 23s, while the page timed out after 16s. The main rebuild also timed out with only “Starting execution” in the logs. Could you check the page backend and build worker? happened to me too we need to fix this takin
Started by techmannihOct 20, 20265 messages
Last active 28 days ago · plain text
<@809856037376491570> the board page is returning 504. The releases-list API took ~23s, while the page timed out after ~16s. The main rebuild also timed out with only “Starting execution” in the logs. Could you check the page backend and build worker?
happened to me too
we need to fix this
taking a look
