0hmx - @Seve https://github.com/tscircuit/rfc/p...
mention https://github.com/tscircuit/rfc/pull/24/changes i think this is good
Started by 0hmxOct 12, 20267 messages
Last active 27 days ago · plain text
<@757706909351411845> https://github.com/tscircuit/rfc/pull/24/changes i think this is good
in the <#1526692261247586464> channel we talk about this a lot- but specifying boards with offsets etc. is bad for assembly
you want boards to generally be specified relative to eachother, relative to connectors etc.
it might be ok
but it would be the most non-preferred option, it's better to say "this board plugs into this board here" etc.
`mountedTo` is a property boards support for 3d assembly, that is much more preferable
we should generally try to eliminate all offsetrs
