Seve - @shibo @Anas this is the size of your mo...
mention mention this is the size of your motors, they all have stranded wire
Started by SeveOct 12, 202622 messages
Last active 27 days ago · plain text
Could you like do a male JST connector?
tf alot of works https://www.youtube.com/shorts/_zl28E2urEU
i crimp a lot of connectors, yes i can crimp, it takes a lot of time, around 10-20 minutes per connector
but crimping is generally "not cool" we could possibly design a JST to wago compat board to avoid me having to crimp
so should I continue with the 1mm pitch JST? I can't make the decision since I can't relate
Sure
Fine i will crimp lol
Honestly id almost rather solder, but crimping you could theoretically source the cables
Make sure it matches the nema and type for the jst
Theres 1mm, 2mm, ph, sh, gh etc
You want both sides to be the same type, will hopefully be eiaser to purchase
Honestly realllllly think about it though, try sourcing the cable, make sure the pins are in the right order
Try to source the cable
<@757706909351411845> is this the motor you got? https://www.amazon.com/dp/B00PJYL6BY the inventory doesn't give a link to the exact motor, and I can't clearly see from your image, some motors have JST connectors, which means if you buy the correct cable you don't need to crimp
none of mine have jst connectors at the end, they ALL have JST connectors at the motor
so basically we remove the cable from the motor and replace it with our "custom cable" but ideally our custom cable is something we can just buy
Yeah meaning if I have the correcr jst on the cable on both sides there is no need for crimping right?
right and it's common enough for us to buy yep
which means we might need a 6 pin connector 😬
