https://tscircuit.com/0hmX/dual-usb-
https://tscircuit.com/0hmX/dual usb peltier assembly not routed review so mostly are the connectors good does it make sense kin dof stuff mention mention
Started by 0hmxOct 13, 202612 messages
https://tscircuit.com/0hmX/dual-usb-peltier-assembly not routed review so mostly are the connectors good does it make sense kin dof stuff <@757706909351411845> <@809856037376491570>
needed the review lol
The build timed out, can you rebuild this
ahh ok
build `34945a02-1c38-4769-8430-4962ca61b1ab` failed with `user_code_job_timeout`: **“Build timed out after 30 minutes.”** The same commit (`49d6c6a`) and configuration pass locally, including `build --ci`. PCB routing is disabled, and no PCB routing solvers start. The downloaded log contains only “Starting execution.” The timeout error is stored separately in the build-status API and isn’t included in the log download. Could you check
Hmm.. something seems off, I just built some of my packages and they built fine
600 files?
Can you get rid of the unnecessary files, I am sure AI must have random files which are not needed?
haa it got fixed <@757706909351411845>
