โ† Back to community index
# designreviewยทActive
@shibo ๐Ÿงต https://tscircuit.com/
mention ๐Ÿงต https://tscircuit.com/ShiboSoftwareDev/nema8 20mm dual usbc stepper controller pcb
Started by SeveOct 10, 202638 messages
Last active 27 days ago ยท plain text
<@778624824875941908> ๐Ÿงต https://tscircuit.com/ShiboSoftwareDev/nema8-20mm-dual-usbc-stepper-controller#pcb
I couldn't find the thread
the route names are still problematic, everything should have an actual net name
it looks like you might have via in pad in a couple places
probably ok tho
The area is too tight
i mean i don't know if they'll charge for that
Net names need to be more descriptive?
they are literally ROUTE_23
this is really hard to understand if you connected your JST properly- it has to match Rishabh's
because i use a particular type of cable
I don't see that name in the schematic
Does that mean they can have different names?
Ill look into it
hmm you're right!!!
i'm not sure why it's doing that but it's concerning
do you have a multi-color led on this
this one is pretty small https://jlcpcb.com/partdetail/XL-1615RGBC-2812B-S/C41413180
i think that's the only major thing. It's really easy to plug these in wrong so i'd be worried if we don't have a way to somehow tell the user something is wrong, also you can't give feedback on temperature, can't debug etc.
i like this board, i think it's coming together, i think it'll sell a lot
people put linear actuators onto them
amazing form factor
You'd have to pre-order from the tscircuit store
<@757706909351411845> I do use a led and a temperature sensor, and the 3d model issue I fixed earlier in core but it's version is stale in the website, I also fixed the net names in the pcb
ok let me know when/what i should review
Last time you wanted to review the jst connections
<@778624824875941908> did you check that the jst connections are identical to Rishabh's-
i would maybe even try to get to 0 warnings because that's just generally a good criteria to have, and it would have cought the LED bug above
also if there's a bad warning, this gives you the opportunity to do a fix for it
i'm very excited for this board btw
Cool
Continue in Discord โ†—
