โ† Back to community index
# designreviewยทActive
https://tscircuit.com/rushabhcodes/ESP32
https://tscircuit.com/rushabhcodes/ESP32 E Reader schematic ๐Ÿ™ ๐Ÿฅบ
Started by ! Rushabh | Linux ShillOct 7, 20268 messages
Last active last month ยท plain text
https://tscircuit.com/rushabhcodes/ESP32-E-Reader#schematic ๐Ÿ™ ๐Ÿฅบ
No mounting holes at the bottom? how will you mount this to the enclousre?
I think you would need some kind of spacers here, which you're missing in the assembly. Maybe think through the assembly more
Not the right switches for the button caps, reference the gameboy switches
to keep the screen away from board??
yeah, the screen can't just fly over there. it needs some support to be kept on
are there any other issue other than assembly
Your pcb board will also need those holes, so that you can screw in the eink display from all around the corner. So keep the dimensions accurate
Continue in Discord โ†—
