https://tscircuit.com/techmannih/NEMA-34
there's also manuyal bridges
Started by SeveOct 6, 2026100 messages
Last active 5 days ago · plain text
you gotta figure out how motor drivers work man
watch videos learn
yea updated. using manual MOSFET bridges are retained because the TMC5160A requires them, allowing the power stage to be sized for the 48 V, 5.5 A RMS-per-phase target. you can review now https://tscircuit.com/techmannih/NEMA-34-Smart-Motor-Mounted-Stepper-Controller#files
Did you take a look at the other NEMA boards which we have ordered?
Reference those boards, I am sure you will spot issues with your board
No, are you referring to the NEMA 23 ? https://tscircuit.com/imrishabh18/nema-23-stepper-controller#3d
reference both nema 17 as well as nema 23
sure
https://tscircuit.com/imrishabh18/rp2040-motor-controller#pcb
<@809856037376491570> <@757706909351411845> These changes are implemented, Separate USB-PD power and USB-DATA ports. USB-powered setup/diagnostics without motor power. TMP102 temperature monitoring and thermal protection. INA240 per-phase current sensing. Tighter gate/bootstrap layout, local decoupling and dedicated Kelvin sense routing.
can you check it https://tscircuit.com/techmannih/nema34-mounted-stepper-controller
can you do the assembly, this doesn't look like it'll fit to me
looks like the holes are in the wrong places
i could be wrong
nice
<@809856037376491570> can you give this a review when you get a chance
you need to add a small encoder to the bottom marked doNotPlace
you can see Rishabh's design for a reference
it has to be perfectly centered, look at how people add encoders to nema17 motors for references on where it goes
what is J7 and J2? If you have any additional connectors you have to justify them
only put on the specified interfaces
<@1067854999889137715> it seems like you still need to do more assembly and review your board, there is no way to connect the motor and there are other issues that i've found that i expect you to discover
please review this carefully, you should have realized you couldn't connect to the motor
i'm pausing my review, this board has issues that you should be discovering
Updated using both NEMA17/NEMA23 references Centered bottom encoder marked doNotPlace. J2: JST VH motor connector with matching harness modeled. J7: consolidated required industrial/control interfaces. J3: external braking resistor connection. Added motor, adapter and mating connectors to the assembly. Added RGB/power indicators, buzzer and programming/test access.
only add jumpers we actually care about
(this should be obvious-)
J2 connects the motor’s two windings. J3 connects the external resistor for regenerative braking. J7 carries STEP/DIR/ENABLE, home/limits, and the specified CAN/RS485/RS232 interfaces. so IN0/IN1 and OUT0/OUT1 have no defined application, so those can be removed and J7 reduced accordingly. Motor control, limits and the required communication interfaces would remain.
it's obvious you're just copy and pasting from ai i.e. FAKE ENGINEERING When did we ask for CAN/RS485/RS232?
what does that connect to?
btw don't answer that hypothetical question, make your board actually decent
do not do fake engineering
hint: if you have a wire that's not connected to anything, then you better be able to explain exactly what product it connects to and have it sourced
sure i am checking them
updated https://tscircuit.com/techmannih/nema34-mounted-stepper-controller J2 is JST4 VH connector that connects directly to the motor. J3 is JST2 VH connector for an external braking resistor. It absorbs energy returned by the motor when slowing down or stopping, preventing the bus voltage from getting too high.
<@809856037376491570> can you check it
Place the usb on the edge, how will you connect this otherwise?
this is not a pinheader?
yea, it is a jst2 VH connector, It mates with a VHR-2N cable housing connected to the external braking resistor
done updated
<@809856037376491570> can you check it now
<@757706909351411845> can you check it now https://tscircuit.com/techmannih/nema34-mounted-stepper-controller J2 is JST4 VH connector that connects directly to the motor. J3 is JST2 VH connector for an external braking resistor. It absorbs energy returned by the motor when slowing down or stopping, preventing the bus voltage from getting too high.
put them in the assembly if they're necessary
<@757706909351411845> updated, can you check it https://tscircuit.com/techmannih/nema34-mounted-stepper-controller
The traces have sharp edges, is this even valid?
wait that's not even trace, it's copper pour
I don't think it's valid
<@809856037376491570> connectivity and different-net clearance checks pass, idk sharp corners make a copper pour invalid.
<@757706909351411845> I checked the nema34 power requirements. We need a USB-C PD EPR adapter that can provide 48 V / 5 A (240 W) from a single port, along with a compatible 240 W USB-C cable
Sapphire
yep you should select one
that one? https://frame.work/products/power-adapter-240w
<@757706909351411845> <@809856037376491570> can I order nema34 now ?
Idk, I am not confident with that board. I have never seen copper pours with that shape tbh
<@809856037376491570> i have updated the copper pour can you check it again
<@757706909351411845> Is this okay, all of these are copper pours and not traces. Is this okay? I am not sure
yea, the wide shapes are power copper pours, and the thin lines visible when the pours are hidden are routed traces. the design uses both.
hard for me to say without seeing the pours
oh
i see yea it's a hack that ai does
not good or bad ig
idk how to feel about it
but it's probably not going to cause issues
yea may be idk, so we can order it if it is looks good?
<@809856037376491570> https://tscircuit.com/techmannih/nema34-mounted-stepper-controller
My concern was that if copper pour were drawn as traces then the drc checks wouldn't be applied on those.
never mention me without a message
(it's disrespectful, am i supposed to read a weeks work of messages and try to figure out what you're talking about?)
sorry, my bad
rishab have concern but I checked the refilled copper in KiCad for shorts, clearance, connectivity and minimum connection width. Those checks passed
wdty? <@757706909351411845>
i think Rishabh can make the call
If kicad DRC is passing (you haven't posted any proof of that afaik) then it's probably not going to have a short
the [KiCad DRC report](https://github.com/techmannih/pd1180-epr/blob/a58e277bcf781e29a529ddc8c464220ce60a4050/release/kicad-drc.json). It reports no shorts, clearance, minimum connection-width or unconnected issues. <@928397102416007238> , could you review also the [copper-check details](https://github.com/techmannih/pd1180-epr/blob/a58e277bcf781e29a529ddc8c464220ce60a4050/docs/copper-geometry-review.md)
wtf is that- open KiCad and show a zero-error DRC dialog
<@1067854999889137715> how can we review a giant json blob
gotcha, im checking it
I used that STEP file https://www.omc-stepperonline.com/s-series-nema-34-stepper-motor-4-8nm-679-87oz-in-14mm-key-way-shaft-1m-cable-34hs31-6004s1 for the assembly based on the motor you ordered https://www.amazon.com/gp/product/B091C83HWF/
I’ve added spring clamps, raw PD voltage measurement via ADC, and implemented power-good monitoring, can you check it now https://tscircuit.com/techmannih/nema34-mounted-stepper-controller
Why do you have a buck boost converter?
i don't think the microcontroller is supposed to be powered by PD
it is powered by data iirc
you have multiple buck boosts and i have no idea why
clean up the schematic, understand every page
this is a huge motor, so you actually have to put effort in
You have a bunch of dumb logic circuits
<@1067854999889137715> understand every chip's purpose
this is not good
