Seve - @Anas @Abse, release pipeline broken due...
mention mention , release pipeline broken due to introduction of clipper lib, we use two polygon libraries: @tscircuit/manifold 2d, and flattenjs (both support polygon offsetting iirc) PR is being reverted, i'm also skeptical that this change was necessary because circuit json el
Started by SeveOct 3, 20262 messages
Last active 7 days ago · plain text
<@756504518417711104> <@398467566588264449>, release pipeline broken due to introduction of clipper-lib, we use two polygon libraries: @tscircuit/manifold-2d, and flattenjs (both support polygon offsetting iirc) PR is being reverted, i'm also skeptical that this change was necessary because circuit json elements have implied solder paste regions https://github.com/tscircuit/core/pull/4349
RE: implied solder paste regions. What is the actual motivation? Gerber generates paste regions for simple polygon offsets already and if it doesn't that would be a bug
