the agent used manual pcb traces to
the agent used manual pcb traces to route my stepper driver board, mention I should force it to use the autorouter correct?
Started by shiboSep 30, 20267 messages
the agent used manual pcb traces to route my stepper driver board, <@809856037376491570> I should force it to use the autorouter correct?
we're expecting most boards to use manual traces, usually after running the autorouter
your usb data lines aren't connected
also how does the user program the mcu?
you need two usb-C ports right
that's your job to figure out
