! Rushabh | Linux Shill - A real example is in ...
A real example is in TI’s TMDS62LEVM board. Its Altium PCB file contains a full circle keepout with a 103 mil centerline radius and 1 mil stroke width Proposal: native annular PCB keepout Add shape: "annulus" to Circuit JSON’s [pcb keepout schema](https://github.com/tscircuit/cir
Started by ! Rushabh | Linux ShillSep 28, 20266 messages
A real example is in TI’s TMDS62LEVM board. Its Altium PCB file contains a full-circle keepout with a 103 mil centerline radius and 1 mil stroke width ## Proposal: native annular PCB keepout Add `shape: "annulus"` to Circuit JSON’s [`pcb_keepout` schema](https://github.com/tscircuit/circuit-json/blob/main/src/pcb/pcb_keepout.ts): ```ts { type: "pcb_keepout", shape: "annulus", pcb_keepout_id: "keepout_1", center: { x: 10, y: 20 }, inner_radius: 1.5, outer_radius: 2.5, layers: ["top"] } ``` The keepout occupies the ring between the two radii; **the center remains usable**. Require `0 < inner_radius < outer_radius` and retain the existing keepout permissions and metadata fields. Circuit JSON already has an `outline` shape, but an annulus would represent this geometry exactly in one element. Implementation would add schema and type tests in `circuit-json`, then update SVG rendering and keepout intersection checks. This converter could replace hundreds of approximate circles with one annulus per Altium full-circle arc: `inner_radius = radius − width / 2` and `outer_radius = radius + width / 2`. It should continue emitting a filled circle when the inner radius is zero or negative.
<@809856037376491570>
you can just use a polygon i think, annulus is a bit weird, i would say "ring"
https://github.com/tscircuit/circuit-json/pull/840/
you should use brep polygons for now
