@Seve https://tscircuit.com/
mention https://tscircuit.com/MustafaMulla29/rp2040 bldc controller Rather than continuing to patch the current BLDC board, I’m considering a clean new board design. Which features should the new board keep, and which parts of the current design are unnecessary? Like should it on
Started by Mustafa7Sep 25, 202636 messages
Mustafa7original post
<@757706909351411845> https://tscircuit.com/MustafaMulla29/rp2040-bldc-controller Rather than continuing to patch the current BLDC board, I’m considering a clean new board design. Which features should the new board keep, and which parts of the current design are unnecessary? Like should it only be usb pd etc. The board should be small right compared to the current board?
i will do a video review now, find industry references
if you don't have an industry reference you're flying blind!
the link is useless to me because it doesn't build
so i can't do a video review
https://tscircuit.com/MustafaMulla29/rp2040-bldc-controller#files <@757706909351411845> review please(follows TI references etc).What do you think I need to add more or remove etc.
New one!
<@1079361271687807026> let me know when the build passes!
make sure your tscircuit version is up to date, you're missing some features
get rid of U_ENABLE_AND
it's doing this in a couple places
source the motor, make sure EVERY connection has a purpose, you have an encoder and a hall effect sensor that we don't have
the whole board needs to be 25% as big
it's huge
find an open source reference design
know what EXACT BLDC motor you're targeting so that we have electrical current requirements for everything, and we know that the voltage is acceptable
https://tscircuit.com/MustafaMulla29/rp2040-bldc-motor-controller#files <@757706909351411845> sorry, I pasted the old link, here is the new one. Am trying to make it even more smaller, will paste the references in short time.
make sure you look at my previous feedback though, it's not spec'd for a particular motor and that's creating issues
make sure you've selected a motor i can purchase
what's the PD negotation voltage?
there's no usbs ports
<@757706909351411845> https://anaheimautomation.com/blwr092s-12v-8000.html How about this motor? and also I should add usbc-pd and usb 2.0 for rp2040 programming?
how common is that? Yes keep USB PD separate
i'm not sure how common that brushless motor is
ideally it's so common we can get it on amazon etc.
https://www.amazon.com/dp/B075DD16LK This?
<@757706909351411845> can you find one? is this good
Sapphire
Sapphire
hello
yes that's fine
