Hey guys can I get a review of this -
Hey guys can I get a review of this https://tscircuit.com/pixalynx/nrf9151 gps tracker 3d
Started by pixalynxSep 23, 202620 messages
pixalynxoriginal post
Hey guys can I get a review of this - https://tscircuit.com/pixalynx/nrf9151-gps-tracker#3d
wow this is looking good
are you sure you want double sided? It will cost more
pixalynx
Thank you !! This was a 10 hour opus 5.5 session on extra
pixalynx
This keeps the small form factor otherwise it will be much bigger ?
wow that's a long time but the results look really good
i would ask the AI to check for schematic issues too, there are a lot
pixalynx
I got chat to peer review and gave it a 9/10 hahahah
pixalynx
My fab-readiness rating Right now I’d put it around: Architecture: 9/10 Schematic: ~8/10 PCB/manufacturing preparation: ~9/10 Production readiness: not yet Prototype readiness after the nRF7002 fix: very close The nRF7002 errata issue is the most valuable finding from this review because the PCB could otherwise boot, connect and appear completely functional while quietly consuming substantially more standby power than expected.
https://cleanshot.com/share/kf7kQqSX
tell ai to run `tsci check schematic-placement` and fix the issues
i think that will do a lot
but it's pretty good
`tsci check shorts` is also sometimes pretty good to run
pixalynx
Ok will do ! Have to wait for my lunch break (currently at work) can’t wait hahaha
pixalynx
I should also add that opus 5.5 used free router to route that board not sure if there is any difference vs doing everything in tscircuit ?
pixalynx
I've updated using your suggestions ! if someone can have a look - https://tscircuit.com/pixalynx/nrf9151-gps-tracker?version=0.1.2#files
pixalynx
acutally did another update this is the latest version - https://tscircuit.com/pixalynx/nrf9151-gps-tracker?version=0.1.4#files
looks good at a glance
pixalynx
I'm going to lose my mind if i send this to fab and it just works 😱
