! Rushabh | Linux Shill - ### Proposal: Treat i...
Proposal: Treat inferred trace length limits as warnings tscircuit automatically assigns a 1 mm maximum length to traces connected to detected decoupling capacitors. When placement exceeds this value, preflight currently stops autorouting for the entire board. This default should
Started by ! Rushabh | Linux ShillSep 23, 20263 messages
### Proposal: Treat inferred trace-length limits as warnings tscircuit automatically assigns a `1 mm` maximum length to traces connected to detected decoupling capacitors. When placement exceeds this value, preflight currently stops autorouting for the entire board. This default should be advisory because: - The [Renesas FS3000 datasheet](https://www.renesas.com/en/document/dst/fs3000-datasheet) specifies the required capacitor values and connections but does not specify a 1 mm trace limit. - SparkFun’s [official FS3000 board design](https://github.com/sparkfun/SparkFun_Air_Velocity_Sensor_FS3000_Qwiic) uses approximately 2.03 mm between `U1.VREG` and the associated capacitor—already longer than tscircuit’s inferred limit. Proposed behavior: - Automatically inferred limits should emit a warning and allow autorouting to continue. - Explicit `maxLength` or `maxDecouplingTraceLength` values should emit an error and stop autorouting when violated. - Store the constraint origin, for example: ```json { "max_length": 1, "max_length_source": "automatic_decoupling" } ``` This preserves useful layout guidance without allowing an undocumented heuristic to block otherwise valid reference-board designs.
<@809856037376491570>
