Ray - bumping this as important and serious, se...
bumping this as important and serious, see latest comments: https://github.com/tscircuit/circuit json to kicad/issues/579
Started by RaySep 23, 202616 messages
Rayoriginal post
bumping this as important and serious, see latest comments: https://github.com/tscircuit/circuit-json-to-kicad/issues/579
<@1079361271687807026>
Ray
and apparently 3 contributors have already opened fixes for #579 (PRs #580, #581 and #587).
Likely Ai spammers, we dont review them. They dont know what theyve written, often no repro
Rushabh has a legit pr thi
https://github.com/tscircuit/circuit-json-to-kicad/pull/581/files
<@1079361271687807026> <@452450065941004289> im afk plz review/figure out
Idk if rushabhs pr fixes it because there isnt a repro in that pr (?)
Make sure rays issue is fixed
the pr got missed in the review channel Previously, the converter numbered symbol pins according to the order in which the symbol library returned them. That order might not match the component’s real pin numbers. The change makes the converter prefer a numeric pin label supplied by the circuit i believe it is correct fix <@1079361271687807026> can yo take a look, i will add a repro if you want
Ray
I guess I had my own PR, you can compare: https://github.com/tscircuit/circuit-json-to-kicad/pull/596
Ray
but it also has failures so ai slop meh 🙂
ok lets merge the repro first if you want?
https://github.com/tscircuit/circuit-json-to-kicad/pull/581/files <@452450065941004289> we merged the repro right, so can you update the pr with regarding the repro
<@452450065941004289> merge this if you feel you have verified my review comment.
<@452450065941004289> you didn't merge this yet? We should not delay user issues. Merge it if you feel you have verified the review changes
