Seve - I dont see a reason currently to add tsx...
I dont see a reason currently to add tsx support for it, where is it used in altium? Is it actually useful?
Started by SeveSep 21, 202616 messages
Krishna
The issue is that some labels hidden in atlium become visible after conversion to cirucit-json In altium, nameone & commenton control to show the components name and comment text So i added is_hidden so the text stays in Circuit JSON, and the renderer won't display it.
Yea maybe we delete
Or you can answer my question haha
If its useful we might add the feature
Krishna
adding that would be usefull Only usecase i have rn is hiding the text that altium mark as hidden
What do they use it for, show a screenshot etc
If its used commonly for something useful
But yea if not we dont need it in tsx, so dont need it in circuit json
Krishna
altium-to-circuitjson This is where I wanted to use is_hidden, to hide the extra silkscreen text. I don't have an sperate tsx use case rn.
Krishna
My earlier approach was to skip hidden text during conversion. Is that okay instead?
Krishna
yes just skip it unless you understand the use case, it doesn't seem like you've mentioned the use case, it might be more of a fabrication note text indicating the part number or something
Krishna
Ok, I will skip text !!
hidden text right?
Krishna
