shibo - @Seve a summary of why the fanout test ...
mention a summary of why the fanout test in core is failing: 1 Core gives the solver incomplete input. The decoupling vias aren’t present when fanout runs. The solver correctly routes through that apparently empty space. 2 Then another issue with the vias included, the solver’s s
Started by shiboSep 8, 20263 messages
<@757706909351411845> a summary of why the fanout test in core is failing: 1 - Core gives the solver incomplete input. The decoupling vias aren’t present when fanout runs. The solver correctly routes through that apparently empty space. 2 - Then another issue with the vias included, the solver’s search strategy was inadequate. It respected the obstacles—it didn’t route through them—but chose routes/reservations in an order that trapped a later DDR bus and failed to find the valid solution. a proposed fix: https://github.com/tscircuit/fanout-solver/pull/192 to the fanout solver issue which will be followed by a fix to core
merged
sorry for the delay
