Abse - @Seve what should we do about vias in cr...
mention what should we do about vias in crystal traces ?
Started by AbseSep 7, 202623 messages
Abseoriginal post
<@757706909351411845> what should we do about vias in crystal traces ?
imo we should detect traces connected to crystals and warn if it has vias
<@757706909351411845> wdyt?
<@398467566588264449> maybe you'd be interested in implementing impedence matching
i think we already do this
but there are just a ton of things that can go wrong
so it needs refinement
e.g. the crystals, if they aren't using crystal elements, need to have a warning to tell the user to use crystal elements
we should honestly like block autorouting if the crystal paths aren't planned
otherwise this board is like pretty sweet
even the usb is somehow impedance matched(!)
<@757706909351411845> first pr https://github.com/tscircuit/checks/pull/272
what does that pr do?
it looks like it actually does the opposite of what you want
it reduces it from an error to a warning?
you want it to be an error ?
oh error when there is a via in crystal trace but warning when not using the crystal element ?
https://github.com/tscircuit/core/pull/3713
Does any autorouter currently support maxViaCount
We might support it but it is a bit of a tough constraint, better solved with pcbPath etc
Since you can pre route the crystal
<@757706909351411845> how should impedance matching be applied ?
