shibo - @Seve these issues are blocking me from...
mention these issues are blocking me from routing the AM62L board, a lot of progress was made, it's nearly there https://github.com/tscircuit/tscircuit autorouter/pull/2247 https://github.com/tscircuit/tscircuit autorouter/pull/2248 https://github.com/tscircuit/tscircuit autorout
Started by shiboAug 27, 202657 messages
<@757706909351411845> these issues are blocking me from routing the AM62L board, a lot of progress was made, it's nearly there https://github.com/tscircuit/tscircuit-autorouter/pull/2247 https://github.com/tscircuit/tscircuit-autorouter/pull/2248 https://github.com/tscircuit/tscircuit-autorouter/pull/2249 https://github.com/tscircuit/tscircuit-autorouter/pull/2250 https://github.com/tscircuit/tscircuit-autorouter/pull/2251
no repro?
only the first PR is mergable
the remainder are super dangerous
I have a repro from my board, but I told it to make the repro as small and focused as possible
i'll use the real thing this time
yes if i had the result i might know a bit better if this was appropriate, there's no dataset to benchmark on, and we don't have bus routing solved outside of the regular autorouter
if you show more evidence then that would help, right now all i see is a bunch of ai generated code
and #2248 is a major bug
AFAIK
also i do appreciate the deep dive into this, i think it is the right method, i do this all the time but i often throw out a bunch because of issues doing review.... it is very hard
<@757706909351411845> please check again: https://github.com/tscircuit/tscircuit-autorouter/pull/2248 https://github.com/tscircuit/tscircuit-autorouter/pull/2249 https://github.com/tscircuit/tscircuit-autorouter/pull/2251
2248 is definitely better
it's from the hdmi that would get connected to the am62l, context poisoning ig
please check the other two: https://github.com/tscircuit/tscircuit-autorouter/pull/2249 https://github.com/tscircuit/tscircuit-autorouter/pull/2251
these are definitely getting better
i think minor tweaks and we can start merging
<@757706909351411845> https://github.com/tscircuit/tiny-hypergraph/pull/173 https://github.com/tscircuit/tscircuit-autorouter/pull/2248
it seems like you want to make it so that certain connections don't traverse certain zs, `portZ` exists on the GraphTopology https://github.com/tscircuit/tiny-hypergraph/blob/main/lib/core.ts#L90
it seems like you want to modify the `TinyHyperGraphProblem` to add support for specifying `routeAllowedZ`
ugh dude i don't think this works
like do you have any proof that this works?
only that small repro
i'm saying
that limiting the layer of a bus doesn't make sense
because a bus always starts on the top or bottom layer, and sometimes you seek to have it traverse in the middle
*traverse without layer changes on a signal layer
you have no support for that
you only have support for complete restriction
even in the infinite cost implementation
if you can't show me a fully routed board with your custom autorouter, what's the point?
MAYBE layer restriction makes sense, or maybe we use explicit autorouting phases for it
idk
yeah, you need to prove something is usefull otherwise it may slow us down longterm
is that what you're saying
but there is a near term performance implicaition
yes no matter what we are paying in performance
i like this general direction, it might be ok
`isPortTransitionAllowed` is being called A LOT, you need to profile this
if `isPortTransitionAllowed` is effectively 0 cost, then maybe we merge it through
it is a good feature but i have no idea if it's going to get us to the finish line, it is a good feature
also stop with the ai generated titles and descriptions for this
I found out hdmi bus doesn't need to be in only one layer
soo
yea it can have transitions, but you need to have the same number of vias on each line generally
ideally the same layer changes around the same areas of the board
you're doing good i'm just having a hard time reviewing these
my issue is that I only focus on getting through the immediate obstacles, I don't think of how these changes would affect the tool as a whole and/or longterm
you're fine, they're good implementations
it's hard to get this stuff working
i'm struggling with managing this because it's hard
however the autorouter is swappable via `autorouter={{ algorithmFn: ... }}`, so you may find you're able to use a fork or PR build to route a board and that is particularly interesting
yea everyone is struggling to make progress here i think
but we are getting meaningful progress don't you think
worth trying
yes we're seeing improvements
