Mustafa7 - Why core tests taking so much time t...
Why core tests taking so much time to finish locally, literally takes hour to finish
Started by Mustafa7Aug 26, 202619 messages
Mustafa7original post
yea not a good idea to run those locally
core has a lot of tests haha
this is common for any big codebase, maybe at some point we reduce them, or we could even start to optimize, but it's fairly common for a codebase with all tests to be too big to run locally
is there any command where i can update snapshots on core prs on github
/us or something
usually ai can just read the PR and see which ones failed tho
that's a bit simpler sometimes
but thats repetetive coz there are like 10 shared bun tests in a matrix
we can disable the early cancellation
(that would fix that issue right)
i'm not having the same issue and i'm not sure why
i'm able to do PRs to core that update snapshots fairly easily
idk if it's because my cpu is running a lot of tests, but you have an M5 right
M4
hmm yea idk
maybe disable the early bail in the workflow
i too face this one , also i do update trace solver like edit the packge.json manually and /us .
