Arhan - I’m recreating the Adafruit Feather RP2...
I’m recreating the Adafruit Feather RP2040 USB Host board in TSCircuit from the official Eagle reference. Placement, netlist, TypeScript, and shorts checks pass. After adding the full support net connectivity, autorouting fails with: code sample PCB traces remain unrouted afterwa
Started by ArhanAug 20, 20267 messages
Arhanoriginal post
I’m recreating the Adafruit Feather RP2040 USB Host board in TSCircuit from the official Eagle reference. Placement, netlist, TypeScript, and shorts checks pass. After adding the full support-net connectivity, autorouting fails with: ```text TypeError: undefined is not an object (evaluating 'connectedPort.x') ``` PCB traces remain unrouted afterward. Could this be a real TSCircuit autorouter issue, or is it more likely caused by my custom footprints/routing model? Worth minimizing into a repro?
I don't think it's an autorouter error, it's a type error
It should be simple to figure out the type you are using incorrectly
Arhan
I traced the TypeError to the USB-C component having missing PCB ports after its standard footprint fetch failed. Is it expected behavior for an incomplete/missing footprint to crash with `connectedPort.x`?
If the fetch failed then autorouting should be blocked
Arhan
I verified this in `core`. The existing USB-C fetch-failure test confirms that a failed standard-footprint fetch can leave the connector with logical ports but zero PCB pads: ```ts expect(circuit.db.pcb_smtpad.list()).toHaveLength(0) ``` From: `tests/repros/repro-usbc-parts-engine-failure-empty-schematic.test.tsx` In `lib/utils/autorouting/getSimpleRouteJsonFromCircuitJson.ts`, the autorouting path maps source ports to PCB ports and filters only `null` values: ```ts const connectedPcbPorts = trace.connected_source_port_ids .map((sourcePortId) => db.pcb_port.getWhere({ source_port_id: sourcePortId })) .filter((pcbPort) => pcbPort !== null) ``` It then accesses: ```ts for (const connectedPort of connectedPcbPorts) { if (connectedPort.x === undefined || connectedPort.y === undefined) { // ... } } ``` When the PCB port is missing, the property access itself throws: ```text TypeError: undefined is not an object (evaluating 'connectedPort.x') ``` Would a failed footprint fetch be expected to block autorouting with a clear error, rather than allowing autorouting to crash?
block routing, show error
