https://imrishabh18--rp2040-motor-
https://imrishabh18 rp2040 motor controller v1 0 6.tscircuit.app/ file=index.circuit.tsx
Started by RishabhAug 19, 202634 messages
Rishabhoriginal post
https://imrishabh18--rp2040-motor-controller-v1-0-6.tscircuit.app/#file=index.circuit.tsx
lgtm
it's wayyy too big tho lol
i would shrink it but otherwise yea looks good
actually
aren't you missing output pins
yea this is totally wrong
you need A+, A-, B+, B- no?
Did multiple rounds of review from codex
how would you plug in a FOUR WIRE stepper motor
oh
you use two terminals for a single motor
yea your silkscreen is really bad
there is no "motor a" and "motor b", there's ONE motor with A+/A- and B+/B-
i think it's not clear- usually that would be a single wire terminal, but even then the silkscreen is super confusing A+/A- is COIL A and B+/B- is COIL B of a single motor
you also called it a DUAL MOTOR
it is not a dual motor driver, it is a single STEPPER motor driver
or am i wrong
is this a brushed motor driver? I don't think so
i'm pretty sure there's a lot of confusion
this is a single stepper motor driver
and there's a ton of stuff mislabeled
it's not a dual motor driver
the fact that codex didn't tell you this indicates it's cooked
also i would shrink the board a lot tbh
https://imrishabh18--rp2040-motor-controller-v1-0-10.tscircuit.app/#file=index.circuit.tsx Have shrunk the size, and the terminal is combined to one 4pin terminal to for nema 17
still very wide tbh
but looking good
one sec will review
https://cleanshot.com/share/DGwVldjl
will take a second to upload
reduced the board size and no more via's on the crystal trace
Looks good!!!
