https://tscircuit.com/techmannih/BOOST-
Review please!! https://tscircuit.com/techmannih/BOOST CC2564MODA files
Started by techmannihAug 19, 202635 messages
Review please!! https://tscircuit.com/techmannih/BOOST-CC2564MODA#files
https://www.ti.com/tool/BOOST-CC2564MODA
make sure to use a HIGH QUALITY AI like Sol Extra High, issues like this should have come up in tsci check
<@1067854999889137715> what is the chip that is like "better than" the mod board- can you add an audio jack? I think this board might not be able to driver a speaker
added the audio codec, headphone jack, and stereo speaker amplifier, cleaned up the schematic, and reran the checks.
Can you please check it,
wdym audio codec?
CC2564MODA outputs digital PCM/I2S audio, so the codec converts it to analog for the headphone jack and speaker amplifier. TPA2012D2 is the actual speaker driver.
Yea i mean maybe we go for it
Can you price it, ill also let <@809856037376491570> review
I REALLY dont like that we’re using the mod so please prepare an alternate with the newer chip
Serious pcb designers dont use modules!!!
I checked the pricing. The current CC2564MODA module is about $15.95
I think we can replace it with the newer, active CC2564C, which costs about $5.01? can use it as alternative?
<@809856037376491570> , can you also check what improvements we can make before the meeting if we're going to show it there?
The holes are a bit weird being placed in the middle. Move them to the corners
It's a 4 layer board?
done,
no i mean prepare the order in jlcpcb
yes <@1067854999889137715> i think you should create a CC2564C-based variant
that would also be useful for ti
<@1067854999889137715> URGENT: push your board with --include-dist YOUR BOARD IS NOT BUILT ON TSCIRCUIT.COM WE CANNOT DEMO
<@809856037376491570> there is an old version here: https://techmannih--boost-cc2564moda-v1-0-16.tscircuit.app/
I am building the new one using admin panel
it had a timeout tho- not sure it would build
i cloned it locally and started to build
Increased the timeout
His config file didn't have the timeout
oh
the old version is honestly good enough
but it is unfortunate
okay, yeh this build might take couple of minutes. So, we should go with that, no option
Latest version https://techmannih--boost-cc2564moda-v1-0-19.tscircuit.app/#file=index.circuit.tsx
