Krishna - @seve what type of jst to implement c...
mention what type of jst to implement can u provide some data sheets !
Started by KrishnaAug 18, 20264 messages
Krishnaoriginal post
<@757706909351411845> what type of jst to implement can u provide some data sheets !
Krishna
for Issue https://github.com/tscircuit/jscad-electronics/issues/268, are these the 3 main JST families you want implemented? JST XH (2.50mm): https://www.jst-mfg.com/product/pdf/eng/eXH.pdf JST PH (2.00mm): https://www.jst-mfg.com/product/pdf/eng/ePH.pdf JST ZH (1.50mm): https://www.jst-mfg.com/product/pdf/eng/eZH.pdf
so jst zh is already implemented
you need to implement xh and ph
