also it looks like you're building
also it looks like you're building support for four motors?
Started by SeveAug 18, 202651 messages
board is electrically for one motor—not four. - The six MOSFETs form three half-bridges: one each for phases U, V, and W. - Four BLDC motors would require 24 MOSFETs and four sets of U/V/W outputs. - The current scattered arrangement makes the six MOSFETs look like separate motor channels.
Will fix the placement
<@757706909351411845> https://tscircuit.com/MustafaMulla29/rp2040-bldc-controller Can you review one last time before ordering, i fixed the placements
hehe i wish i had the circuit json to look at
can you push dist locally
`tsci push --include-dist` or something
that way you have a site i can view, we'll also have a record of what you're actually ordering
did you pass `tsci check shorts`
Yea
niceee
<@398467566588264449> can you review it as well
<@398467566588264449> Is this ready to order?
mustafa can you please push with dist?
so that there's a record of what was built
one sec
Yes i did, its connected to github repo
can you make sure these chatgpt concerns are not real if they are can you address them
<@1079361271687807026> the build is failing you need to push dist
we cant see it on the website, push dist
ok pushed
can you add USB PD support or is that too difficult? This requires a 12V power supply
i can do the 12V power supply but it would be better to add a barrel jack as well for me to plug into
Ok will try
<@757706909351411845> <@398467566588264449> https://tscircuit.com/MustafaMulla29/rp2040-bldc-controller#files Done! Can you please review again(added usb pd and barrel jack)
Also seve check the drcs arent those false positive?
waiting for build
gotta go to bed in a sec tho
I pushed the dist, for some reason build is failing on cloud
I discussed this with rishabh, not sure what the issue is
there are no previews, how are we supposed to review
normally we just click the preview site
oh wait i can hit 3d etc.
lots of empty space on the board- you can probably shrink it
It's coz the rp2040 from common is at the middle of the board, we cannot change it's individual components position
https://cleanshot.com/share/RlpY7lQ8
you can't change the common rp2040 position? It should be able to be decomposed, CC <@398467566588264449> people need to be able to move the USB-C port etc.
we have a couple options for moving the USB-C etc, e.g. using a composable pattern with context e.g. ``` <Microcontroller_RP2040> <MicrocontrollerRP2040.USBC pcbX={...} pcbY={...} /> </Microcontroller_RP2040> ```
that can be done in usercode
*userland
<@398467566588264449> any idea how to fix this?
I think this will work we can try it ``` <Microcontroller_RP2040> <MicrocontrollerRP2040.USBC pcbX={...} pcbY={...} /> </Microcontroller_RP2040> ```
I will try to do it now
https://tscircuit.com/MustafaMulla29/rp2040-bldc-controller#files <@757706909351411845> review please, I shrinked the board , not sure if we can do more.
when you `tsci build` throw in the `--site` flag and _i think_ we should have a browsable site for this board which is very useful
<@1079361271687807026> i think you're G2G
but fwiw the board can be shrunk much more 😄
start uploading to JLC, you may find more issues
hopefully you have the account?
Yea
