gokul - I have imported C62857 into a circuit a...
I have imported C62857 into a circuit and noticed that the PCB has all 8 pads, but the schematic only shows one capacitor with 2 terminals. Since this part contains four independent capacitors, should we fix it by representing multi pin capacitor arrays as chips? mention mention
Started by gokulAug 14, 20264 messages
gokuloriginal post
I have imported C62857 into a circuit and noticed that the PCB has all 8 pads, but the schematic only shows one capacitor with 2 terminals. Since this part contains four independent capacitors, should we fix it by representing multi-pin capacitor arrays as chips? <@757706909351411845> <@809856037376491570>
<@756504518417711104> This is related to the change you made in easyeda
I think you missed adding the symbol prop to the `<capacitor />`
gokul
https://github.com/tscircuit/easyeda-converter/pull/450 <@809856037376491570> please take a look
