shibo - RE: circuit-json-to-altium
RE: circuit json to altium
Started by shiboAug 13, 202611 messages
<@757706909351411845> this pr is stacked over your pr in altiumts: https://github.com/tscircuit/altiumts/pull/43
this bootstraps the repo circuit-json-to-altium, and makes it actually work, tested with the boosterpack boards: https://github.com/tscircuit/circuit-json-to-altium/pull/1
and this imports the logic from circuit-json-to-altium inside the boosterpack repo instead of defining it locally: https://github.com/tscircuit/boosterpacks.tscircuit.com/pull/2
after that I can try to implement this export method inside datasheet-to-tscircuit
<@757706909351411845> can we make this in time?
I implemented export to kicad which downloads the zip file
It would be super counterproductive to merge that iiuc because you didnt use the converter pattern?
We can merge the gihub link thing tho
Converter pattern and circuit json and altium snapshots side by side is 10x faster forndevelopment
and should I use it also in datasheet-to-tscircuit for now?
