0hmx - AI is doing this a lot## Browser Impor...
AI is doing this a lot Browser Import Error The error occurred because the AI used a directory import: code sample Node.js and Bun automatically resolve this to ./imports/index.ts, but the browser evaluator may not. Use an explicit path instead: code sample Or import the file dir
Started by 0hmxAug 7, 20263 messages
AI is doing this a lot ## Browser Import Error The error occurred because the AI used a directory import: ```ts import { Part } from "./imports" ``` Node.js and Bun automatically resolve this to `./imports/index.ts`, but the browser evaluator may not. Use an explicit path instead: ```ts import { Part } from "./imports/index" ``` Or import the file directly: ```ts import { Part } from "./imports/Part" ``` The mistake was assuming all environments use Node-style import resolution. For reliable tscircuit code, idk what is the best
because tsci build works with './imports' the ai can not see this error will happen in the browser. and './imports' will not work
it has to give the full path
