Mustafa7 - @Seve You’re right—the common board...
mention code sample is this a valid issue or we have to use maxTraceLength/maxLength?
Started by Mustafa7Aug 4, 20262 messages
Mustafa7original post
<@757706909351411845> ```You’re right—the common board itself is now failing with a different error. The capacitor placement issue is fixed. The new problem originates in `tscircuit/core`: - `Y1` is a four-pin crystal. - Pins 1 and 3 are oscillator signals. - Pins 2 and 4 are connected to GND. - Core currently applies the crystal’s default 10 mm limit to every crystal-connected net, including the entire GND network. - Some GND endpoints are 20.88 mm apart, so routing is skipped. The proper fix is in [Crystal.ts](/Users/mustafamulla/Desktop/tscircuit-repos/core/lib/components/normal-components/Crystal.ts:90): apply the 10 mm rule only to signal pins 1 and 3 for four-pin crystals. No `1000mm` workaround is needed.``` is this a valid issue or we have to use `maxTraceLength`/`maxLength`?
yea that is valid!
