Mustafa7 - @! Rushabh | Linux Shill If i delete...
mention If i delete the index.tsx file the editor getting stuck at this loading state
Started by Mustafa7Aug 3, 202622 messages
Goes back to normal if i again create a new file
will fix in now
i really appreciate your feedback, thank you 🙏
<@452450065941004289> where are the "import" and "format" options in the editor? i cannot see them
right click for format button
i had added added import button on an older pr but forget to add in the the pr which got merged, will add it now
https://github.com/tscircuit/tscircuit.com/pull/4220
will take a look now
https://github.com/microsoft/monaco-editor/issues/5296 well ig its time to raise a pr in microsoft's repo
Cannot use the editor with these errors
can you explain a bit
As you can see in the image board has a closing tag but it still throws an error and in the second image why does it throw an error even the capacitance is defined?
name="C_VCP
here " is missing
see line 21
it is working as intended
will show the same even if you open in vscode
Oh ok
