Got this one today!!! super cool
Started by mohan-beeJul 30, 202653 messages
https://tscircuit.com/mohan-bee/keychain
<@757706909351411845> <@&1420812538421051555>
Vanuan
Does it light up?
yeaa.. not that bright..
probably I need to change the battery
Vanuan
I wonder if there's any difference between shorting using finger or shorting using some jumper wire. So maybe it's not a battery, but the high resistance of your skin
Vanuan
Maybe some small touch sensitive switch components would be more reliable, though kind of reduces the coolness factor
yea i literally had this thought after placing order
okay then will soldering those copper pads .. work ??
Vanuan
The alternative is some mechanical jumper wire you put on the key chain. Makes you imagine being a car thief 🤭
lol
Vanuan
Soldering one end of the wire with some duct tape on the other pad maybe 🤔
Vanuan
Or some pretentioned spring
hmm... wil do
Vanuan
capacitive touch would be cool
Vanuan
MOSFET might be an even better solution. Short the gate pin with your skin, deliver full power to the led
yea that's cool
Vanuan
I assume the capacitive sensor is for use cases where the switch is hidden behind a plastic case. This is the opposite of that
like you said hand is the problem
i burned a led . By direct supply hehe
i am worst in soldering 😖
now added a 3v coin cell at the back
Vanuan
Now you need some OVP and properly calculate the value of those resistors 🙃 . Though 220k seems to be plenty
Vanuan
You used bench power supply instead of battery?
no i attached a coin cell at the back
i bought this module
Vanuan
Shouldn't have burnt out
no i just kept the 9v directly on the led terminla
so that burned only one led where i kept
Vanuan
Where 9v is coming from
no that is a seperate battery
and then i used this module at the back add a 3v coin cell
soldred
everything works
fine now
only without hand
Vanuan
Yeah, 9V is too much, red led requires around 2V.
yea
Vanuan
Lower resistance make them brighter. Though would make battery life shorter
yea that's ok for .. i do have a switch .. so i think managable ..
Vanuan
So BS_08_B2AA010_R is not used here: https://tscircuit.com/mohan-bee/keychain ?
no that was in the older version
haha that looks super bright
is there a resistor?
Yes
