astrimid - It feels like I'm fighting LLM again...
It feels like I'm fighting LLM again. This is schPinArrangement property of <chip : code sample When I ask LLM to do counter clockwise, it seems to change both direction to "right to left" and reverse pins in a list. Is there a prompt that makes it do either pin reversal or chang
Started by astrimidJul 21, 202655 messages
It feels like I'm fighting LLM again. This is schPinArrangement property of `<chip>`: ``` topSide: { direction: "left-to-right" as const, pins: [ "CS1", // Pin 1 (leftmost) "VFB1", // Pin 2 "VREG3", // Pin 3 "VFB2", // Pin 4 "CS2", // Pin 5 (rightmost) "TP", // Pin 21 ], }, ``` When I ask LLM to do counter clockwise, it seems to change both direction to "right-to-left" and reverse pins in a list. Is there a prompt that makes it do either pin reversal or change direction?
Ok, LLM can generate a prompt, but can't follow it 😩 : ``` For the counter-clockwise layout, keep pins in ascending order (Pin 1, 2, 3, 4, 5) and use the direction property to control placement: - Top side: direction "right-to-left" (so Pin 1 appears on the left) - Right side: direction "bottom-to-top" (so Pin 6 appears on top) - Bottom side: direction "left-to-right" (so Pin 11 appears on the right) - Left side: direction "top-to-bottom" (so Pin 16 appears at the bottom) ``` ``` For the counter-clockwise layout, use direction "left-to-right" for all sides and reverse the pin order: - Top side: ["CS2", "VFB2", "VREG3", "VFB1", "CS1"] // Pin 5 to Pin 1 - Right side: ["DRVH2", "VBST2", "SW2", "PGOOD", "EN2"] // Pin 10 to Pin 6 - Bottom side: ["DRVL1", "VO1", "VREG5", "VIN", "DRVL2"] // Pin 15 to Pin 11 - Left side: ["EN1", "VCLK", "SW1", "VBST1", "DRVH1"] // Pin 20 to Pin 16 ```
it seems to overeager to help and uses both
``` For the counter-clockwise numerical layout: IMPORTANT: Choose EXACTLY ONE of these two methods, DO NOT combine them. METHOD A (Recommended): Use direction only - Keep ALL pins in ascending order (Pin 1, 2, 3, 4, 5) - Use ONLY the direction property to position them - DO NOT reverse the pin order in the pins array Top side: direction "right-to-left" → pins: ["CS1", "VFB1", "VREG3", "VFB2", "CS2"] Right side: direction "bottom-to-top" → pins: ["EN2", "PGOOD", "SW2", "VBST2", "DRVH2"] Bottom side: direction "left-to-right" → pins: ["DRVL2", "VIN", "VREG5", "VO1", "DRVL1"] Left side: direction "top-to-bottom" → pins: ["DRVH1", "VBST1", "SW1", "VCLK", "EN1"] OR METHOD B: Use pin order only - Keep ALL directions as "left-to-right" (or "top-to-bottom") - Reverse ONLY the pin order in the pins array - DO NOT change the direction properties Top side: direction "left-to-right" → pins: ["CS2", "VFB2", "VREG3", "VFB1", "CS1"] Right side: direction "top-to-bottom" → pins: ["DRVH2", "VBST2", "SW2", "PGOOD", "EN2"] Bottom side: direction "right-to-left" → pins: ["DRVL1", "VO1", "VREG5", "VIN", "DRVL2"] Left side: direction "bottom-to-top" → pins: ["EN1", "VCLK", "SW1", "VBST1", "DRVH1"] CONFIRM: You are using ONLY Method A OR ONLY Method B, not both. ```
ok. this might be correct prompt for top pins, but completely wrong for bottom pins
It feels like I would specify it much faster manually.
what model are you using
we could try to improve the API to something that makes less mistakes
CC <@809856037376491570> related to some stuff you're doing
this prompt seem to work ``` Create a counter-clockwise pin arrangement for a {PACKAGE_TYPE} package where Pin 1 is at the top-left corner. Package details: - Total pins: {TOTAL_PINS} (including thermal pad if applicable) - Pins per side: {PINS_PER_SIDE} - Pin 1 location: top-left corner - Thermal pad pin: {THERMAL_PIN_NUMBER} (if applicable, placed after the last pin on the top side) IMPORTANT: Follow Method A ONLY (do not combine with Method B). Method A (use direction property to control placement, keep pins in ascending order): For each side, use the direction property to position pins correctly: Top side: - direction: "right-to-left" - pins array: [{PIN_1}, {PIN_2}, ..., {PIN_N}, {THERMAL_PIN}] - This places Pin 1 on the LEFT and Pin N on the RIGHT - Thermal pad (if present) goes after Pin N Left side: - direction: "top-to-bottom" - pins array: [{PIN_N+1}, {PIN_N+2}, ..., {PIN_2N}] - This places Pin N+1 on TOP and Pin 2N on BOTTOM Bottom side: - direction: "left-to-right" - pins array: [{PIN_2N+1}, {PIN_2N+2}, ..., {PIN_3N}] - This places Pin 2N+1 on the LEFT and Pin 3N on the RIGHT Right side: - direction: "bottom-to-top" - pins array: [{PIN_3N+1}, {PIN_3N+2}, ..., {PIN_4N}] - This places Pin 3N+1 on BOTTOM and Pin 4N on TOP CRITICAL RULES: 1. DO NOT reverse the pin order in the pins array - keep them in ascending order (1,2,3,4,5...) 2. ONLY use the direction property to control visual placement 3. The resulting layout should have Pin 1 at top-left and go counter-clockwise: Top → Left → Bottom → Right 4. Pin numbers should be in ascending order around the package Generate the schPinArrangement object with these specifications. ```
I'm using deepseek
maybe there's a simple clockwise and counter-clockwise pin arrangement preset for qfn chip footprint?
Could probably define a simple helper function ``` const pinLabels16 = { pin1: "VCC", pin2: "GND", pin3: "EN", pin4: "FB", pin5: "SW", pin6: "PG", pin7: "VIN", pin8: "VOUT", pin9: "COMP", pin10: "SS", pin11: "CLK", pin12: "SYNC", pin13: "AGND", pin14: "PGND", pin15: "BOOT", pin16: "PH", } export const schPinArrangementQFN16 = generateQFNPinArrangement({ pinsPerSide: 4, pinLabels: pinLabels16, // thermalPadPin: undefined // No thermal pad }) ```
Maybe this API: ``` interface QFNConfig { pinsPerSide: number pinLabels: Record<string, string> /** * The corner where Pin 1 is located. * This ALONE determines the orientation. */ pin1Corner: "top-left" | "top-right" | "bottom-right" | "bottom-left" /** * Direction of pin numbering around the package. * This ALONE determines the order. */ numberingDirection: "counter-clockwise" | "clockwise" thermalPadPin?: string } ``` OTOH, maybe schRotation is better for pin1Corner?
Thinking a bit more, pin1corner is a bit confusing, maybe pin1side is better: ``` const schPinArrangementRightCounter = generateQFNPinArrangement({ pinsPerSide: 4, pinLabels: pinLabels16, pin1Side: "right", numberingDirection: "counter-clockwise", }) ```
My first package: https://tscircuit.com/astrimid/qfn-numbering-direction/blob/index.tsx Is there a way to mark it as an API package?
Also, it's a schematic only package. Is there a way to disable pcb?
congrats on the first package!!!!
yes you can disable pcb
can't seem to find a way to do it. Is it some metadata? It seems even if I don't use `<board`, it's automatically populated.
setting footpint to empty string generates errors: ``` pcb_missing_footprint_error:No footprint specified for component: <chip#2747 name=".TopCW" /> ```
`pcbDisabled` is passed in platformConfig
platformConfig? where do I set it?
Are you using just the tscircuit.com editor, or the cli?
tscircuit.com
Type '{ children: Element[]; pcbDisabled: boolean; }' is not assignable to type 'BoardProps'.
oh do you want to use this locally? The web editor is a bit hard to use
normally you would edit tscircuit.config.json
doesn't appear to have any effect
Looking into it
should it be *.ts?
No, I am adding a fix. `pcbDisabled` isn't a supported flag in `tscircuit.config.json` . I am adding that support
This appears to work: export default { platformConfig: { pcbDisabled: true } }
using *.ts
Okay, but the `tscircuit.config.json` should be working as well in sometime
Okay. So, I've created a package, but how do I import it? `import { generateQFNPinArrangement } from "astrimid/qfn-numbering-direction"` doesn't seem to work? Should there be some package.json ?
You don't export it
the error says : Could not fetch "astrimid/qfn-numbering-direction" from https://cdn.jsdelivr.net/npm/astrimid/qfn-numbering-direction/+esm:
also, exporting funtion I see the error: Execution Error:Error evaluating "entrypoint.tsx": Cannot read properties of undefined (reading '0')
if exporting functions not supported, I might need to define it as a JSX element?
Taking a look, it should work though
Testing this package, it works
I think you missed the `@tsci/*` prefix
import { MyChip } from "@tsci/astrimid.qfn-numbering-direction"
Thanks, it works! Could you also help with ``` export { generateQFNPinArrangement, MyChip }; export type { QFNConfig, SchematicPinArrangement }``` This seem to generate cryptic error
``` Execution Error:Error evaluating "entrypoint.tsx": Cannot read properties of undefined (reading '0') at importLocalFile (blob:https://tscircuit.com/5fa13c9c-631c-41ef-887a-dcdc1228d044:955:2290) at async importEvalPath (blob:https://tscircuit.com/5fa13c9c-631c-41ef-887a-dcdc1228d044:973:743) at async Object.executeWithFsMap (blob:https://tscircuit.com/5fa13c9c-631c-41ef-887a-dcdc1228d044:1007:729596) @tscircuit/eval@0.0.1030 • @tscircuit/core@0.0.1474 ```
Ok, it seems I can't export just a function, I must export a function and a component
Awesome: https://tscircuit.com/editor?#data:application/gzip;base64,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
Still see Module '"@tsci/astrimid.qfn-numbering-direction"' has no exported member 'generateQFNPinArrangement', but running it works
interesting, CC <@809856037376491570> this is a type export error yea? maybe we're messing up the type bundle
i launched an improvement for the errors today fwiw
hopefully that particular error will be improved in the future
I tried it but didn't see the error
What I notice it is more often reproducible when I open it in incognito. So might be some kind of race condition or caching issue.
Yep i think so
