Anas - @Sevewe need Vercel deployment for this...
mention we need Vercel deployment for this repo https://github.com/tscircuit/datasheet to tscircuit
Started by AnasJul 13, 20269 messages
Anasoriginal post
<@757706909351411845> we need Vercel deployment for this repo https://github.com/tscircuit/datasheet-to-tscircuit
i'm on it
<@756504518417711104> you can't run the agent via an api endpoint on vercel- look for off the shelf solutions or alternate approaches
the backend should likely use a service like cloudflare that specializes in containerized runners. If there is a backend component, it needs to be closed source so we don't get immediately hijacked
(create-repo should support creating a private backend)
the private backend would need to use vercel if we do it
this is to say- focus on local usage. We can't do a vercel deployment for this- i attempted to deploy the repo to vercel and it deployed but it won't work properly with vercel as the backend unless vercel offers a containerized runner service- afaik they don't, but maybe you can also try to figure that out- idk
for the demo it could probably run local
sg
