! Rushabh | Linux Shill - quick question: do we...
quick question: do we need to add add poppygl to @tscircuit/internal dynamic import
Started by ! Rushabh | Linux ShillJul 10, 202625 messages
quick question: do we need to add add `poppygl` to `@tscircuit/internal-dynamic-import`
<@757706909351411845> <@778624824875941908>
did you face an issue?
yeah
`circuit-json-to-3d-png` uses it in tscircui.com
yea i think that's fine, there's no issues with adding additional things to be dynamically imported i think
``` Error Downloading 3d PNG Error: Failed to download 3d PNG: TypeError: Failed to fetch dynamically imported module: https://jscdn.tscircuit.com/poppygl/latest/+esm ```
no downside really as long as it's dynamically loaded in browsers only
oh hmm
that seems like an issue with the jscdn not poppygl
that's a jscdn issue
do you have access https://github.com/tscircuit/jscdn.tscircuit.com
yeah
i wanted to do something like this ```ts await Promise.all([ loadCircuitJsonConverter("circuit-json-to-gltf"), loadCircuitJsonConverter("poppygl"), ]) return loadCircuitJsonConverter<CircuitJsonTo3dPngModule>( "circuit-json-to-3d-png", ) ```
but this does not make sense
i am confused
wait, lemm me cook
will report later
so, for step we do this ```ts const ensureCircuitJsonToGltfLoaded = async (): Promise<CircuitJsonToGltfModule> => { return loadCircuitJsonConverter<CircuitJsonToGltfModule>( "circuit-json-to-gltf", ) } export const loadCircuitJsonToStep = async (): Promise<CircuitJsonToStepModule> => { // circuit-json-to-step dynamically imports circuit-json-to-gltf at runtime. await ensureCircuitJsonToGltfLoaded() return loadCircuitJsonConverter<CircuitJsonToStepModule>( "circuit-json-to-step", ) } ``` we can do similar pr `poppygl` if it is in `@tscircuit/internal-dynamic-import` wdyt
no idea, <@398467566588264449> I think has a better idea about this repo
<@757706909351411845> can you check this, don't know how jscdn work
hello
i think the fix is in the jscdn mostly
if you fix the underlying jscdn bug, you don't need to orchestrate installations IIUC
